Cross pin stuck(or the big shinny pin)any tips
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
Okay the screw broke off that holds the cross pin from moving so what do i do?
Car: 2002 Z28
Re: Cross pin stuck(or the big shinny pin)any tips
get it out would be the logical thing to do. try welding a nut on it, if that doesn't work 90* drill, the threads are at the top of the bolt so it won't take much to get it out.
Car: 2002 Z28
go to kragen or another parts store and get an easy out set, drill through the screw/bolt and use the easy out bit to back it out. Worked when i broke a fuel filter thread on my friend's carb.
Car: 04 GTO
Transmission: M12 T56
You won't be able to reuse the carrier, but an easy way around this problem is to take a heavy duty cut off wheel to both sides of the crosspin right where the pin goes through. Once you cut through it it will drop out.
1 Post
Car: 92 Z28 heritage
Engine: 5.0 TPI
HOLD ON!!! There is a tool for this, I have one. Actually it is a kit, it comes with a very long flexible drill bit, a locating threaded insert to align the long drill bit, an easy out, and instructions. I have used it and it works great. I will check tomorrow at work who makes it and a art number for you.
Car: 04 GTO
When you don't need to use the carrier again, special tools or an exercise in zen patience aren't really needed. 5 minutes of cutting might actually even be a little more fun when it comes down to it. That's all i was saying.
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
this happened to me when i was taking apart a 3.23 open rear so i just took a heavy hammer and a big punch and set it through destroying the carrior
Car: '82 Z28
I had problems with mine today when putting in the new locker. Rounded the head off then cut a slot for a screwdriver. Broke the screwdriver, started on it with a cold chisel to try and back it out, tried some vice grips a couple times. After an hour of pounding on it, my dad comes along and I tell him my troubles plus I had to go meet someone really quick. I take off and come back later, he got it out with a new pair of vice grips with no effort LOL After my hour of suffering, he does 10 seconds of work hehehe.
Hotrodboba400
12-10-2019 07:07 PM
gta892000
09-16-2015 12:37 AM
