power trax locker
Car: 83 Camaro
Transmission: th350
power trax locker
ok i am looking into getting a power trax locker and i wanna know which one i should get.....also do i need a 7.5" or 7.625
http://store.summitracing.com/partde...%2D0775%2D2605
http://store.summitracing.com/partde...art=PWT%2D1930
Car: 82 camaro SC
Re: power trax locker
The first one(more expensive new style) is smoother when it locks and unlocks. The second one is the older style. I'm running the older style one(6+ years)--you would never know I had a locker until I turned really short in a parking lot, it makes a clicking sound.
Location: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Make sure spline# is correct.
I called Powertrax to 2x check.
The unit works great- I had my rear-end apart after putting on about 1000 miles and there was no visable wear. I like it alot.
S-D
S-D
INCORRECT!!! the parts are not interchangeble. the 7 5/8 is larger. the carrier is wider. the portion of the locker that slides onto the axles are much wider for the 7.625 then on the 7.5. i have both rearends and both lockers. the best way to find out what you have is to pull the cover and look on the ring gear. the measurements are right there. please be sure of your ring gear/carrier size before purchase!
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
So then when powertrax told me they were interchangable and I ordered from Summit I got lucky that I got the right part??
i guess so, cause i know that when i look at the one for the 7.625, the outer two portions are much wider (by like an 1/8") than the one for the 7.5. i tried to put the 7.5 in my 7.625 carrier and it didn't even come close to lining up right. the center section may be the part that powertrax is talking about being interchangeble. the portion that the springs slide into and the center pin holds things tight, yeah that piece, they are interchangable, but the locker as a whole is not.
