700r4/3.42s/2800stall/LT4hotcam
1 Post
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
I'm still thinking about a T56-to-700r4 swap. I just can't decide. Selling my T56 and getting the money shouldn't be a problem. It seems like everyone wants a T56. LOL What kind of gains do you guys think I'll gain by just going to a 2800-3000 stalled auto over my T56/3.42s? Also, anyone else running a 700r4 and 3.42s? According to f-body.org's MPH/gear calculator its going to run down the interstate at 2500RPMs at 80mph. Does that seem right? What kind of MPG you guys get with a 700r4 and 3.42s. Also what disadvantages do the 700r4 and stall have??
*I'm thinking about a pro-built auto and a vigilante converter
When I break my WC-T5 I plan on going with the 700r4. It is just really difficult to get traction out of first gear with a manual trans. I think the T5 and T56 have similiar 1rst gears. With the broad torque of a "cammed" 350 I think the auto trans with 2800 rpm stall is the way to go at the drag strip. An the overdrive makes it liveable on the highway. That's my opinion
1 Post
Car: '91 GTA
Engine: 402ci LS2
yeah, the T56 is actually geared really high out of the hole. It only has a 2.66 1st gear compared to the T5's 2.95 and the 700r4's 3.06 ratio. I love driving the stick, but I think I'd rather be faster at the track with the auto
Car: 2002 Z28
Pro Built automatics ( www.pro-built.net ) sells a Street/Strip Th700r4 that is suppose to handle up to 550HP with their ACT 9.5" torque converter. The tranny is $1395 and the TC is $565. THis is the setup that ill be going with this summer.
Car: 89 firebird, 03 Avalanche z71
Engine: 5.0 stock (for now)
Transmission: 700R4 auto
Axle/Gears: stock 2.73 for now
re:
I recently put in 3.42s w/my 700r4, the two seem to work together great, I dont have a higher stall converter or anything, but so far i love it, just the problem with the 2500rpms a highway speeds seems to literally suck the gas right out the tank, but city driving has improved since i no longer need to put it half way to the floor to get upto speed w/my non-lower end torque cam.
Car: 2002 Z28
I have 3.73s in my auto 90 RS and i have not noticed any difference in gas mileage with the gears. About once every month or so i drive home from college (250 miles each way) and notice about 22-25mpg. RPMs are not that bad, 3.73s in 4th gear makes the car run at lower RPMs than if you had 2.73s in 3rd gear. Im not at 2500RPMs until i hit about 75MPH.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Wanna trade tranny's and computers?
I've got a complete 4L60E Manual to Auto swap-over kit with transgo shiftkit already installed.
1 Post
Car: '91 GTA
Engine: 402ci LS2
Thanks for the input guys! I might be selling it in the next month to a guy and calling pro-built! Thanks again! Also, does this all sound right???
Parts:
700r4 tranny
vig stall converter (3000rpm)
auto x-member
flexplate
correct speedo gears for the tranny
remote mount tranny cooler (B&M or something)
auto shifter
TV cable
some sort of TCC lockup device
*Anything else I'd need?? Any thing else I need to be warned of??
Parts:
700r4 tranny
auto x-member
flexplate
auto shifter
TV cable
