700R4 slipping
700R4 slipping
today while coming home from work i gave the car some throttle and it down shifted fine but the RPM's went up real fast but finally cought around 4500rpm. the problem is like a manual transmission car when the clutch is sliping but its a auto. any idea on what this could be?
It could be a number of things. First thing to do is ensure that the fluid level is correct. Low fluid level could it. Also a plugged/dirty filter could starve the trans momentarily till the revs got enough fluid pumped to apply the clutches.
Originally posted by 87 B4Z
the fluid level is fine. could it be the converter going out?
Good luck.
Pull the pan and check out the debris in the bottom, if there isn't too much you might want to look at the pump or somewhere in that vicinity. Not trying to be the beare of bad news but from expirience you probably have a fried clutch. Good luck to you, hopefully its not fried.
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
