Will HITHERE 4th Gen Rear and Alum Driveshaft work in my 86 w/700r4?
Car: 1986 Pontiac Firebird S/E
Engine: LG4 TPI Conversion
Axle/Gears: 3.42 SLP Posi 10 Bolt
Will the 4th Gen Alum Driveshaft work in 86 w/700r4?
Wil a 4th gen Alum DS work in an 86 w/700R4? The donor car is a 2002 Firehawk w/ 6spd.
Ok....that was a cool answer. The answer is yes the driveshaft and rear end with fit your 86 fine. The rear will be slightly longer on each side tho. And you will have to run adaptors or different rim spacing in the back. Not sure what the spacing is on the 4th gens tho.
Many Thanks
Good, I'm glad to hear it will fit. I am also getting the rear from the car as well. The owner upgraded to a Carbon-fiber unit and a Moser 3.73 12 bolt. Because i helped withth install I get the "old" (12,000 mi) DS and 3.42 Posi. All I need to do is find me some rotors, calipers, e-brake cables, prop. valve and backing plates. Again, thaks for the info, as I was unsure of the difference btw. auto and manual (if there was one).
from what I've researched, the Driveshaft will fit a third gen rear as well... The rears are virtually the same (slightly longer axles and housings on the 4th gen) I just didn't see that anywhere in here, and now here it is
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
