U-Joint Part #'s
Car: 86 iroc
Engine: 355 TPI
U-Joint Part #'s
Ok so I got an aluminum driveshaft out of a 2000 camaro 3" in diamater. The sticker reads Three Rivers #12564003 AU #00001742. I went to have the U-Joints replaced & was told that they are special u-joints due to the driveshaft being aluminum. They were having a hard time finding the U-Joints that would fit it properly. So I went to a GM dealer & had them look up the part # they said the part # was 12471502 changed it to part # 12479126. After looking @ the new u-joints which were $85.00 apiece it didn't have the nylon rings around then like the ones that were on the old u-joints. I'm just wondering if anyone knew the correct part#'s for the replacement U-Joints. Do the have to have those nylon rings on them??? Thanks in Advance
Car: 86 iroc
Engine: 355 TPI
I guess I should of added that I have an 86 w/700r4. ANYONE have any problems replacing there u-joints with this driveshaft?
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I got one for mine at Advance Auto. I had to get a front u-joint to get the one that fit. It happened to be the same part number as the one for my '84 K5 Blazer. It was a Brute Force, solid non-greasable type. $8 IIRC.
Also,
https://www.thirdgen.org/techbb2/sho...ighlight=joint
HTH...Ed
Also,
HTH...Ed
LT1Formula
20
11-14-2015 12:02 AM
Thomas
10-03-2015 05:34 PM
