Borg Warner tranny ID
I have an 82 TA that has had the engine and tranny swapped
it is a 350 4 spd. The tranny is a Borg Warner but how do I figure out if its a T10 or whatever. I wrote down all of the info on the transmission if any one could help or send me to a web site that has id numbers on it. These are some of the numbers on the tranny. Numbers that are casteded on the tranny are 1304065903 Fpc4. on the tail shaft these numbers are stamped
13-04-066-906. also on the tranny are 4001tlm, 18.82.9,
2c152-582 , WK912. this is everything I could find on the housing.If there is anyone out there who can make sense of these numbers please post a reply or e-mail me thanks. By the way one of the reasons I need to know what I have is I need to get a new drive gear for the speedo it is way off and I have already got the biggest driven gear I could buy.
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Easiest way to tell if it is a T10 is if the reverse gear shaft is located on the tailshaft of the trans.The shafts for 1-4 are located on the side plate as usual.If the reverse gear shaft is on the side plate also you have a Saginaw.Is the torque arm mount cast into the tailshaft of the trans or is it a retrofit looking mount?The numbers I can help non on..sorry.Someone else should be able to.
[ON] 9 Bolt Axles Partout
6speedIROC
16
03-15-2023 08:33 PM
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
1304065903, 1304066, 1304066906, borg, borgwarner, camaro, housing, id, identification, numbers, shaft, special, t10, tail, transmission, transmissions, warner
