signs of a bad syncro??
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey guys i am wondering if thise would be a sign of bad syncros. when i get on it and shift fast at liek 5-5500 rpm the tranny will grind going itno gear but goes rigth in. also like every once in a while it will be hard to get into gear for no reason. oh yea one more thing, i put 4 quarts of synthetic atf in my t-5, woudl putting in to much effect anything? thanks guys
Car: 89 Formula
Engine: Carbed 5.7
how much is normal? shoudl i put the ca ron rams and take out the top filler screw and just let it come out till it stops?
it should be at or real close to the bottom of the top hole(the filler hole, not the drain hole) just fill it until it hits that mark, drive it for a couple miles, then check it again.. add as necessary
Car: 89 Formula
Engine: Carbed 5.7
well i put 4 quarts in and i have drivin it and it hasn;t leaked. will it be acurate if i drive the front of ramps and do it. or do i have to make the car level ?
Abubaca
11-05-2016 12:22 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
09-22-2015 08:28 PM
