Anyone ever cut the tailshaft of a trans?
Old 02-23-2003, 11:25 PM
flyin89's Avatar
If you cut it with a cutoff wheel to adapt it to a 4X4 case will there be any ill effects? I have a 350TH I'd like to hook to an AWD transfer case for my S-10 4X4. I realize the shaft is hardened but
the wheel shouldn't generate to much heat. I know theres an adapter kit but the trans is in perfect shape(and hopefully would be after this mod. What do you guys think?
Old 02-25-2003, 07:53 PM
Nordbert's Avatar
I've used a cutoff wheel to shorten the output shaft for a 4WD
700-r4 to TH350 conversion. It won't overheat the shaft.
Old 02-28-2003, 09:34 PM
Supporter/Moderator
askulte's Avatar
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
One of the guys on the CamaroZ28 board was snapping T56 output shafts, so he swapped over to the larger diameter Viper shaft, and cut it shorter. No big deal...
Jeremys87
07-14-2022 09:08 PM
midge54
09-02-2020 07:13 PM
dennisbernal91z
Fabrication
29
03-02-2017 12:04 PM
Reddeath210
10-06-2015 08:20 AM
TheJoeY88
08-13-2015 06:51 PM
Quick Reply: Anyone ever cut the tailshaft of a trans?
