Probably going to use the 4L60E, what is a good/cheap higher stall converter?
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Due to finances and time, I may not have the chance to swap tanny's with my brother so I may be stuck with the auto for a while. I have the stock converter but my LT1 will have the LT4 hotcam in it and I'd probably be better off with a slightly higher stall speed. What are some decent ones that aren't too expensive?
Will ones from a 3rd gen 700R4 work?
1 Post
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
if the ones from a thirdgen will work as well then you might look into possibly picking up, from dacco/detroit, a stock vette converter. stalls at about 2400, especially with your mods and will only set you back 76 bucks + 25 core charge. they've stood up to everything i'v eseen thrown at them so far including 150 hp shots of nitrous multiple times down the track and street use.
1 Post
check out http://www.atra.net/buyersguide/bgalpha/alphacd.html and scroll down till you see the dacco/detroit logo. i'd look under there and see which one falls closer to you. maybe i can get robert, mrr23, to chime in with the part number. hes the one who introduced us all to that converter. that guy is a parts dork. hit 'em up on aim if you want at mrrjjdh03 on aim/aol, or possibly venture over to fl-thirdgen.org and search through our boards. i know the part number is over there but don't have the time right this moment to look it up.
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Last 4L60E convertor I priced from Dacco was just $10 more than a 700 convertor, and that was just because most (I think) use the PWM convertor setup. The convertors for the PWM setup (which makes TCC lockup smoother) have a different TCC clutch material. When I rebuild a 4L60E, I get the Transgo kit for it, which does away with the PWM (and the worn valve body that results) then you don't need to have a 4L60E convertor. In fact, this is what I plan to do when I get to my S-10 project!
Car: 84 Z28
From what I understand you can. I forget exactly how it's worded in the transgo kit instructions, but it says something like this.
Hotrodboba400
12-10-2019 07:07 PM
MikkoV
09-09-2015 04:25 PM
