Driveshaft ???will it fit or not
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 86 iroc
Engine: 355 TPI
Ok I went to the boneyard today & found an aluiminum driveshaft near a newer camaro.Or should I say front half of a newer camaro,anyways.The sticker on it says Three Rivers #12564003 AU Other number to right of it is #00001742. I went to GMpartsdirect & looked it up but it didn't have much of a discription on the find. So can anyone help me out with this does anyone know what it went too & if it's a camaro will it fit in my 86 w/700r4?? If it doesn't i won't feel bad cause I only paid $50.00 for it. Thanks in Advance.
It will fit. Is it aluminum? That would be a sweet deal. I would go and get it balanced just to make sure its ok before you put it on though. Balancing usually runs about 50 dollars out here.
Car: 86 iroc
Engine: 355 TPI
yes it is aluminum it was a sweet deal that's why I didn't pass it up. I just wanted to make sure it's gonna fit before I go out into the cold & try it. :lala: I'm happy to here that it will fit thanks for the reply.Is anyone else running a 700r4 with this driveshaft??? I do plan on getting it balanced & new U-joints.
Car: 86 iroc
Engine: 355 TPI
There are no dents or anything & the weights are on it. I think I'm just going to replace the u-joints & throw it in there & give it a try. I probally should of done some homework on it, but I was there & there was only 1 driveshaft that was aluminum & 3". I wasn't even sure if it fit a camaro but it was sitting in a burned up 00 camaro but the shaft looked to be in great condition.. I just hope I got lucky & everything is fine with it
If not I now know what to look for in the future.
![Roll Eyes (Sarcastic)](https://www.thirdgen.org/forums/images/smilies/rolleyes.gif)
I 'believe' I've read that this shaft is a fit for our cars; however, here are some dimensions from the 1LE thirdgen shaft that may assist:
Length from U-joint center to U-joint center is 41 1/2. Diameter approx 2 3/4 in. The part # is 10085375.
The fourthgen LS1 part # is 12564003. Diameter is approx 3 in.
I was forced to change U-joint sizes on my 85 IROC to get the shaft to fit. I used CarQuest part # 3-3130. I suggest you'll be in the same boat with your 86 (88 and up should be a bolt in).
JamesC
JamesC
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
New2Chevy
09-28-2015 12:35 AM
