TH-350 swap?
Car: 87 Iroc
Transmission: Tremec Tko
TH-350 swap?
I have an 83 camaro with a 200c and would like to swap to a TH-350, what length tailshaft should I look for so I dont have to swap shafts? Anything else I would need?
According to a chart from gnttype.org, the TH350 with a 6" tailhousing is a direct swap. Same driveshaft. Same mount location. You will probably need a different bracket for the
shift cable, though. Different bolt spacing on the pan. Just order
one for a late '70's Camaro or Firebird with a TH350 and floor shifter from a GM dealer or modify the one you have.
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
200c is basically a sick t-350. Your 350-6in tranny will swap in with no problems. I envy you, i looked for-ever trying to find a driveshaft out of a 82-83 camaro with a 3spd auto. brad
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
