what does 3-series differential mean???
Old 12-10-2002, 09:21 PM
chefdan1's Avatar
on the slp take-off differential units what does this mean?? also if i am changing from a stock 2:73 rear-end to this unit what will i need?? i want a posi rear with 3:42 that are capable of handling around 300-330 horsepower?? thanks guys
Old 12-10-2002, 11:16 PM
TGO - 10 Year Member
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
GM creates ring and pinion gears in roughly the same thicknesses. The deeper you go in gear ratios the thicker the gear needs to be. Instead of making a real thick gear they simply move the thickness of the carrier over to compensate. If you used a series 2 set of gear on a series 3 carrier, they would either have too much clearance between the ring and pinion or then wouldn't mesh at all.
The 10 bolt changes carriers at 3.08 gears. 3.08 and beloc are 2 series. 3.23 and higher are 3 series. You can buy extra thick 3 series gears to fit in a 2 series carrier.
When I still ran a 10 bolt I was putting close to 500 hp through Motive 4.10 gears. The weak link in a 7.5" 10 bolt is still the tiny ring and pinion. The teeth are very small and the deeper you go in gear, the smaller the teeth get.
Veaceonee
09-29-2016 08:15 PM
dbrochard
01-28-2016 08:42 AM
meeklay812
10-01-2015 03:46 PM
usafirebird
09-29-2015 11:58 PM
dbrochard
09-19-2015 08:13 PM
Quick Reply: what does 3-series differential mean???
