700r Adjusting The Govenor
ok i have a bit of a prob im trying to adjust the govenor now it shifts just fine wot but its the PT thats the prob it shifts to soon and i know you can grind on the weights to get it right
the problem is now because i installed the .500 boost valve and super survo .
to anyone who has done this a seek your help , are the larger things that just flop around the items that control the part throtle shift, and if so how much should i grind off of them ? then do the smaller weights on the inside control the wot shift points?
thnaks
thnaks
thanks pro built ,
the info was helpfull it did alow it to shift about 200 rpm higher but its still a bit to low, is there anything else i could try.
thanks again
bill
thanks again
bill
Make sure the TV cable is adjusted correctly, if it is tight at WOT then you could install the "over the center correcter" from Sonnax, this will allow later shifts at light throttle openings without affecting the WOT shifts.
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Hey Dana, could you explain a little more of what this Sonnax gizmo does?
Also, will removing the light governor spring raise the WOT shift points as well? Or does it only affect PT shifts?
thanks -MIC-
thanks -MIC-
The inner weights affect the WOT shift points, the springs change this slightly. The part from Sonnax goes on the TV cable at the end where it starts to pull and it will compress first before pulling the TV cable out of position, thus allowing more TV pressure and therefore later part throttle shifts.
Car: Bee-Bowdy
Axle/Gears: fo-tins
Ok. I get it.
I got some info on my shifting problem before. My 1-2 shift is perfect but my 2-3 shift is a little early, but I can deal with it. I think you or TransFixLeo said that a heavier 2-3 shift valve (?) spring would make the 2-3 shift higher.
My point is I'd like to have higher PT shifts but didn't want to upset the 1-2 shift.
thanks
thanks
LT1Formula
10-08-2015 08:34 PM
