clutch for tremec? and suggestions other than CF-DF2?
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
Im putting a tremec in a 3rd gen..
Whats the difference in these two?
http://128bitencrypted.com/centerfor...rchresults.tpl
DF161057 and DF161056?
Description Cylinders Size Input Shaft Disc P/N Centerforce I Centerforce II Dual Friction T.O. Bearing
FORD MUSTANG, MUSTANG II, COBRA
1986-1995
5.0L 302 ENG.
w/ 26 SPLINE AFTERMARKET TRANS. 8 CYLINDER INCHES: 10/1/02 1-1/8-26 -
$N/A DF161057
$484.95
1996-1999
4.6L 280 ENG. SOHC
$N/A DF161057
$484.95
DF161056
CHEVROLET CAMARO, Z-28
1984-1992
5.0L 305 ENG.
8 CYLINDER INCHES: 10.4 1-1/8-26 384161
(Disc Not Included) DF161056
$365.95
5.7L 350 ENG.
DF161056
$365.95
PONTIAC FIREBIRD, TRANS AM
1984-1992
5.0L 305 & 5.7L 350 ENG.
DF161056
$365.95
(Disc Included)
1986-1995
5.0L 302 ENG.
$N/A DF161057
$484.95
1996-1999
4.6L 280 ENG. SOHC
$N/A DF161057
$484.95
DF161056
1984-1992
5.0L 305 ENG.
$365.95
5.7L 350 ENG.
DF161056
$365.95
1984-1992
DF161056
$365.95
(Disc Included)
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I run the part # DF161056 in my Z and have no complaints to date.When I looked into converting to a Tremec..Forte's said that I could run that clutch with the Tremec TKO.
The throwout bearing is different. F*rds use a different arrangement for that
I have the tko in my car.....people are under the assumption (because mike forte makes it look that way) that tremec makes the tranny that you get from him....the only thing that tremec makes in those trannies is the internals, and the design....alot of the parts on those trannies are machined for fortes and assembled by them. they install the input shafts, (the case may be slightly different as well).
however i have no problems with mine
Drone358
12-10-2015 08:16 PM
topteam54
10-06-2015 12:21 AM
Night rider327
09-02-2015 04:17 AM
