Dana 44 Experts! please enter
Car: 88 Camaro
Engine: 355
Transmission: TH-350
I wanted to know if anybody has ever put pre-89 disc brakes on a Dana 44...............please help me out!
thanks
thanks
Car: 88 Camaro
Engine: 355
Well that's good to hear but was there any difficulties or anything I should know before tackling this project?
The reason I'm asking is cause there seems to be an abundance of pre-89 setups and hardly anything after.
thanks
thanks
Car: 86 Aero TA
Engine: ZZ4
Transmission: T-56 Rear: Dana 44
Just use the caliper mounting plates from a pre 89 10 bolt, shouldn't be a problem. Unless you have a 44 with the weird weeny yoke.
Car: 88 Camaro
Engine: 355
C'mon someone has to have some info on this topic.?.?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What would the yoke have to do with the brakes? In any case the Dana 44 uses all the same brake parts as the 10 bolt.
Car: 86 Aero TA
Engine: ZZ4
Hey, you know what? You are right! It has absolutely nothing to do with the brake setup. The hardest part of the swap for me was finding a bastard u-joint to fit the Inland alum. driveshaft (with its 1300 series u-joint) to the stock size yoke on the 44. If you have a stock driveshaft, it's probably not an issue. Sorry for the confusion.
As far as the brakes go, it was no problem.
Car: 86 Aero TA
Engine: ZZ4
Have you checked with SLP? I don't think they have any left. When I got mine over a year ago, they said it was one of the last ones they had. Anyway, good luck!
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Re: Dana 44 Experts! please enter
thanks
thanks
I'm now the one wondering how this is done. What exactly is the difference in the pre and post 89 rear disc brakes and how do you go about adapting them? I can't find 89-92 rear disc brakes parts anywhere and I'm too poor to buy them new.
Car: 88 Camaro
Engine: 355
Re: Re: Dana 44 Experts! please enter
Originally posted by 88IROC350TPI
.....BACK FROM THE DEAD.....
Car: '89 IROC-Z
How do you figure? Aren't the brakes different on 9-bolts? I'm almost positive they are.
Car: 88 Camaro
Engine: 355
