th350- quart capacity?
9 i think, it's been a while since i had one empty. try 5 or 6 and check it, plus you'll have to bleed the air out to get an accurate indiaction on the dip stick.
Car: '94 Corvette
A routine oil change is around 5 or so.
If it's dry, meaning freshly rebuilt with new converter, than like 'ede' said 9-13??? can remember either At least have a case ready...
At least dump 3 or 4 quarts, than start adding while the car is running so it can circulate. Don't overfill :nono: The oil will heat up, and begin to expand rising the level.
Ron
Ron
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
If fresh rebuild, put 1 quart in new convertor and 6 in tranny with stock pan, I believe, have to go back and count the left overs in the shop as I just did this a few weeks ago.
11 quarts in a 350? Sure your not talking about a 700r4 or something, hell I still got 5 bottles left in the brand new case when I installed my new 350.
Hotrodboba400
12-10-2019 07:07 PM
Navy8125
08-17-2015 01:29 PM
