Rebuild question..ATTN Probuilt or Transfixleo
Car: 91 RS
Engine: 350 TBI
Well I finally lost 3rd gear this week (Yall were right about needing a rebuild by the way--this proves it). Anyways, my trusted 30 year tranny man is doing it, and I'm having him install a Trans-go shift kit, a Corvette servo, and an extra transmission cooler......am I missing anything that yall would include while it's apart??
I'm currently in search for a LS1 driveshaft to lesson the punishment and to lose some parasitic power loss.
....and does the shift kit fix that no shift at WOT problem or does that require something else??
I'm sure that Probuilt & Leo will offer their good advice, and I will offer my humble opinion. There are many upgrades, even by the factory, that can be retro-fitted back to earlier 700R4's. TransGo also offers revisions for the 3/4 clutch springs, pump rings & other components to improve durability. The one thing you really need, is to upgrade your 3/4 clutch pack for more friction disks. I believe stock is 6 disks & various kits allow you to increase it to 7,8,or 9 disks. GM offers an upgraded apply plate from a 4L60 which takes the place of 3 parts in the 700R4, thereby giving more space in the 3/4 clutch pack for you to increase the number of friction disks and/or use thicker steel sepatator plates. Using thicker steels helps disipate heat from the clutch pack.
Also, make sure you change your shell drum to the latest GM part. Even if your shell drum looks fine, it is subject to fatigue cracks at the spline. The latest GM shell has a radiused spline hub to improve durability. Hope this helps.
Regards, FJK
Regards, FJK
To go along with what FJK said I like the 4L60E 3-4 pack complete. I would use High Evergy Borg Warner Frictions and Band along with the TransGo Reprogramming Kit, not the Shift Kit. Install a new Input Sprag too. Use either Regular Dexron ATF or full Synthetic- not any "special" oils. Use a TruCool cooler and bypass the Radiator. The TransGo Kit will not give you the WOT 3-4 shift. Get the GM package for that.
3.8TransAM
09-27-2015 08:37 PM
