how and where to put trans sender in pan?
Old 07-28-2002 | 07:07 PM
383LT1intake's Avatar
Car: 92 camaro
Engine: 383 stroker
Transmission: probuilt 700r4
where do i put it in the pan? and whats best way to mount it in the pan? if you have any pics taht would be great later
Old 07-28-2002 | 07:43 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I mounted mine in the cooler return line. I don't want to know how hot the oil is in the tranny but if the cooler is bringing the temperature down enough. Hot oil returning to the pan tells me it's not good enough.
There's nothing wrong with mounting it in the pan but you will need clearance checks. The valve body is usually very close to the pan.
Old 07-28-2002 | 08:33 PM
BOTTLEDZ28's Avatar
Transmission: A4
I mounted my trans temp sender on the teturn line also. i bought the sender that jegs has for $40. it just mounts inline on the trans line that goes into radiator. i had a tranny cooler also . i didnt want a hole in my trans pan.
Old 07-28-2002 | 08:37 PM
scauffiel's Avatar
I drilled a hole for mine in my deep aluminum pan.
I don't think there'd be enough clearance for it with a stock pan.
S.
Old 07-30-2002 | 01:25 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I have my sender in the pan in the same place scauffiel
does.
maroe624
04-16-2017 08:29 AM
NBrehm
08-25-2015 11:49 PM
mizz0313
08-12-2015 06:45 AM
Leggman1
08-06-2015 04:15 AM
Quick Reply: how and where to put trans sender in pan?
