How many LBS. GVW Trans cooler should i get.
1 Post
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I am getting a trans cooler for my car. My question is how much cooling should I get, as in what lbs. GVW rating? Also when installing a trans cooler should I run the fluid through the stock transmission cooler then into the new transmission cooler or just bypass the stock cooler?
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Run it through both coolers for extra cooling. It's there, why not use it?
12000 lbs GVW should work fine.
Use the largest plate style coolers such as B&M's. The plate style coolers are the most efficient transmission coolers out there and they are more compact in size compared to tube and fin style coolers. I use my cooler in conjunction to the cooler on the radiator. Hope this helps.
toronto formula
11-10-2015 06:17 AM
