9 bolt 10 bolt question
I have a 9 bolt rear and was thinking about purchasing a 10 bolt to replace the 9 bolt. will my disc brake setup fit on the 10 bolt?
Yes, the 10-bolt will fit your car and long as it is from an 82-88 f-body. The ones from 89-92 have a different brake setup and require modification. I just did the opposite 2 weeks ago. I swapped out my 10-bolt for a 9-bolt that I got from and 88 Trans Am.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
huh? He didn't ask if the diff would fit.
yes and no. The calipers and rotors are the same but the mounting bracket is different. The mounting flange on a drum brake axle is different than a disk brake mounting flange. You will have to do some modifications and drill some new holes to get it to work.
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
