pressing U-joints out of a driveshaft.. how??
Old 06-04-2002, 09:39 PM
MrJ
MrJ's Avatar
The rear u-joint on my driveshaft has gone bad. I brought it to my friend's house, since he has a table mounted vise. We can't figure out how exactly to press the u-joint out. I had heard something about using a big socket and a small socket, but can't remember the details. The Chilton's was next to useless, as usual.. talking about tool 'J-9533-3' or some vague nonsense like that. Also, how do you install the new u-joint..? thanx a lot
Old 06-04-2002, 10:58 PM
nsimmons's Avatar
Old 06-04-2002, 11:10 PM
MrJ
MrJ's Avatar
thank you.. that is IMMENSELY useful. I did a little more research, it seems there is a plastic retainer that has to be melted with a torch before the u joint can be pressed out.. I don't have a torch, any ideas on way around this?
Old 06-04-2002, 11:15 PM
nsimmons's Avatar
the only retainer is a little metal snap ring just pull it out with pliers
ive heard of people using torches to, but i didnt need one after i took the snap ring off the joint just pushed right out. Use some grease when reinstalling.
Old 06-04-2002, 11:36 PM
MrJ
MrJ's Avatar
that looks like an aluminum driveshaft. I'm almost positive that the regular ones have some kind of plastic retainer (not a ring though) running through the end caps on the closed yokes. Damn I'm confusing myself... I'll take a look at it again tomorrow. Thanx again
Old 06-05-2002, 12:30 AM
nsimmons's Avatar
could be..thats a vette half shaft in the pictures..i've never done it on a camaro
Old 06-05-2002, 01:44 AM
93ND500's Avatar
The factory uses a fiberglass resin to hold in the u-joints. The axle shaft is assembled, and then the resin is injected into the hubs. This fills a groove that is in both the joint and hub. You have to melt this stuff out, and then press out the joints. Just be prepared to cuss some GM engineers.
Forgot to mention that the replacement u-joints will come with new retainer rings(C-clips).
Old 06-05-2002, 11:33 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
You can use a small portable propane torch. Be careful you can over heat the grease inside the cap & have it blow off, spraying hot grease.
manualbrakes.com
Brakes
63
04-09-2024 11:55 AM
86maro_252
10-10-2015 06:52 PM
oil pan 4
Fabrication
10-06-2015 11:56 AM
Justins86bird
09-27-2015 09:43 AM
Quick Reply: pressing U-joints out of a driveshaft.. how??
