Tranny option choices
Old 04-28-2002 | 09:26 PM
capn_crash84's Avatar
I'm started work on my 86 T/A, and i'm starting to plan the drivetrain. I had a 400 pontiac engine bought, but when i found out how complicated that swap would be, i decided to put a 305 back in for the time being. Now i need to choose a tranny.I narrowed it down to three choices, but i have some questions i hoped you could answer for me
1.)th700r4- What is the max amount of horsepower you can push through these things with out causing problems. Eventualy, i want a motor pushing about 400hp, and i don't want to have to worry about bad trannys. They are also fairly expensive to build, so that is a turn off.
2.)th2004r- What did this tranny come in originaly. I can live with the 2.74 first gear ratio, and the .67 fourth gear ratio would make good for cruising. How much power can one of these handle?
3.)Th350- Is this the same as a turbo 350? Again, what is the max hp it can handle.
And a couple more questions. The 700r4 is the easiest to put in. What about the other two? I know that they are shorter and smaller, so will i need a new tranny crosmember? relocate the old one? Also, will i have to change the driveshaft, or the tailshaft(i think thats what they call it).
And finally, is the 350, and the 2004r available in electronic speedo? or would i have to do something there too?
Thanks alot. I appreciate any help you could give me.
-crash
Old 04-29-2002 | 11:02 AM
Anyone have any info??
I also saw in another post that the th375 (found in trucks?) is something else i should consider. Does anyone know the gears, or anything about this one?
-crash
89-IROCZ-5.0TPI
02-22-2022 09:26 PM
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
gixxer92
05-18-2017 11:20 AM
david068513
09-18-2015 10:36 AM
IROCZ1989
09-04-2015 11:54 AM
Quick Reply: Tranny option choices
