How (not) to port a base...
Car: 04 GTO
Transmission: M12 T56
Here are some lousy in-progress shots of my spare base. Yes i'm gonna run it even with the screw ups and yes it still has a lot of work coming to it...
http://home1.gte.net/res0t8sj/base/
send it off for some $5 tig work
I know your pain i was siamesing a tpi base this weekend, yet i stayed within the walls
Its a beeyatch getting the back of the wall cut out, even worse gettin the alum flake out of your hair
Car: '99 HO Z28 / '03 Trailblazer
That makes sense...
But i like to look like i accomplished something when i walk out of the shop
Nothing like walking into the local quicky mart covered from head to toe in aluminum flake and be like "...... WUT?"
lol i always seem to run out of cigarettes half way into any type of car work im doing, so i'll run out to the quick check down the road lookin like a grease moster. and it never fails, there's always the cutest chick in there somewhere that you're ashamed to even smile at cause you look like a bum
Car: 04 GTO
and hide behind the rack...you're kidding right? Who cares how filthy you are. Chicks dig confident guys, not those that hide cuz they have their face painted like braveheart w/ grease, even gives you a good conversation starter.
Car: 04 GTO
Yeah, they dig it. I think it has to do with chicks digging a man who isn't afraid to 'get dirty' when he's 'working'.
You know, i actually heard there are people who won't have sex unless they just got out of the shower. And they're afraid to actually touch any of the important parts. Weird folks. I bet they drive saturns
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
ED...You should have sent the base to ICON MOTORSPORTS of CINCINNATI....I would have done it on the mill for you.... I dont care to make 500 bases but would have hooked an ICON brother up...
Kenwood
-=ICON Motorsports=-
Kenwood
Car: 04 GTO
No really you can do my current base. I'll swap on this one, then i'll port my stock one, maybe matched to some runners, get it all powdercoated or something. I could really do a better job on the intake faces now that i have some practice. And then i don't have a mar from the hole in this one (lol)
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
Here is a shot of my base. It took a while to do all the porting, but I had the time. I just got her running last saturday. Started up fine, and ran good with no leaks. Just that the timing was off a bit. Can't wait to drive it. I have more photos if someone would like to see.
Car: 04 GTO
I just worry abotu the epoxy putty because of the temperature cycling it's going to take. I'm sure short term it'd be fine, but after a year of hot / cool cycles, on that thin piece of metal, it wouldn't take much for it to crack.
Car: 1987 GTA
Transmission: th400
Axle/Gears: 9" ford
Use DEVCON.... I use it to PLUG the EGR ports in the plenum so I can MILL the floor lower.... Its basically a metallic paste that expands and contracts at the same rate aluminum does...And if you get the good stuff you can MACHINE it.... Tough stuff for sure..
Car: 1988 IROC-Z
I am also sure you can patch that hole. Aluminum is quite easy to work with, so try the above fixes. I am attaching another photo of my manifold. It is the pic that I really wanted to attach in my first post. I went 3" deep on both sides, and made everything smooth.
Car: 04 GTO
Yeah, that looks about the same as mine are going to end up. I plan on doing the same work on the opening that you did, smoothing the length of it, and you can see what i'm doing to the head face.
On a stock base, I've actually wondered if it would be possible and how effective it would be if you cut a square section from the top of the ports (center of one port to the center of the next) and welded in a flat section of plate. What this would do is open the top of the ports simular to the Big Mouth intakes. Instead of having the figure *8* shapped ports it would be more of a *B* shape (only laying down on it's side ) You would also remove the center divider at the same time and blend it in where the port divides back into 2 ports again. Is this clear as mud? Since this is just theory I don't have any pics.
Also...if you cut back your SLP runners approx 2" - 3" on each runner, how much more effective would a stock ported base be over an unported stock base?
Car: 04 GTO
Thats not an all bad idea. Except, instead of welding a plate on, why not just fill in the indentation w/ weld and then simply grind it open up higher. You'd still have to use something more substantial like epoxy / whetever to fill in the short side curve of each runner to straighten it out like i wanted to.
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
I feel your pain When I did mine, I went thru the wall near the thermostat housing. I had it welded then ported it again, though I was a bit more careful the second time
