Crank swap for a 305 TPI
Car: 1995 Camaro Z28
Engine: 5.7 LT1
Axle/Gears: Strange 12 bolt w/ 4.11s
I was wondering if anyone has done or thought about swapping the crankshaft from a '94-'97 264 motor into a 305 block? I was thinking of doing this in my '85 Z. I think with good heads, hi-flow runners, base, plenum and a good cam this combination would really pull in the upper midrange and topend.
Engine: 5.7 LT1
Why would it be so bad? As long as its a newer 305 block with the 1 piece rear seal it'd be Ok. As for power characteristics IDK. I tried the combo on Dyno 2000 and my power peak would be around 5700 rpms. Thats a little high for TPI I think.
Engine: 5.7 LT1
Hey! better yet, offset grind the crank and use early small journal rods to give you a stroke of 2.9x. I'll bet if you try hard enough, and spend lots of money, you build a 25x c.i. TPI small block with 250 lb-ft and 200 hp.
Car: 2002 SOM z28
Sanjay
08-12-2015 03:41 PM
