who is running a lt1 cam
I am looking into putting a 96-97 LT1 cam in my 350 tpi engine. i have the 91-93 caprice engine with a crappy cam in it now. what do i have to do to the heads to get this cam to work right. i plan on using 1.6 roller rockers also, can the cam just go in by itself. the engine is brand new and on the engine stand still. i do have a LT4 HOT camkit but i think that cam is too much for the heads on the engine and then i would have to have a custom made chip. i just want to put the lt1 cam in and go thats all. it is going in a 91z28 with tpi and mods listed in sig.
bottle i have a ? for you also..... im looking into putting a t56 in and im wondering what all the "little costs" will be......
1 $ Tranny
2 $ Crossmember
4 $ Electric to mechanical speedometer thing
5 $ ETC???
What am i looking at price wise for the whole thing???
1 $ Tranny
2 $ Crossmember
5 $ ETC???
for the effort, swapping in the LT1 cam wouldnt be worth it. take a look:
what your running now first and LT1 cam second:
.403/.415 202/206 115
.447/.459 201/208 116
you would be better off just going with some 1.6 rockers, it will give you the same results
With the 1.6 rockers you'll be roughly .477/.489 lift 205/207 deg duration @.050 and a 117 lsa.
Some people will say it's not worth it to install an LT1 cam,but with 1.6 rockers and hogging the snot out of your heads as I did,you will see a big improvement over stock. With the LT4 hotcam you'll want to get some better flowing heads.
1988iroc350tpi
08-14-2015 07:52 PM
1992 Trans Am
08-08-2015 08:16 PM
