What Mods Do U Recomend....Both LB9 and L98 engines
Old 03-01-2002 | 04:49 PM
iroc_cragg's Avatar
Hey
What mods do u guys suggest for a 1985 - 1990 305 TPI. What are the best mods that u can get for the LB9 engine. What other things should be done to the LB9 engines to make them perform there best. Thanks for ur input.
List Ur Camaro/Trans Am mods that u have done to ur LB9 engines, what kind of performance gain did u feel from the mods and what mods do u think are the best for the LB9 engine.
All u L98 guys...what kinda mods have u done to ur L98 engines that u think could be done to the LB9. List Ur L98 Camaro/Trans am mods that u have done to ur engines. Which mods are the best for the L98 engines. What mods do u think are a must. What mods should be done to the LB9 and L98 engines. What mods work the best for the L98 and are a must have. Thanks for ur input.
http://camaroz28.cardomain.com/id/56424
Attached Thumbnails What Mods Do U Recomend....Both LB9 and L98 engines-iroc5small.jpg
Old 03-01-2002 | 10:27 PM
87transam5.7tpi's Avatar
well I haven't done alot of mods yet, but here is my opinion. first thing I would do is ignition stuff. I did a catback first but I had a chance to put on an aftermarket coil for just a little bit and it was really nice. and I know with my car the ignition is just kinda slopy and dead. so if I were you I'd do igntion,exhaust then some work on a ram air unit or something to that manner. hope this helps a little bit.
Old 03-03-2002 | 09:03 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Mods are in the sig.
My MAF is dead so the A/F is WAY off. I also have to get a set of runners and a 52mm throttle body to spruce it up a little more. But it's comming along. The cam and the comverter alone would have turned it into a completley new car.
As for what I gained. I feel it's a little faster
Robert
Old 03-03-2002 | 09:48 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
I would recommend upgrade to 3.42 or 3.73 gears, good catback, a set of headers. I think these are the best bang for the buck
Old 03-04-2002 | 01:06 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Well, this is a BL9 Engine 305 5 speed in a GTA, The "must" mods are headers, cat-back and some sort of intake mod be it homemade or afrtmrtkt and maybe a chip. I'd say that'll give you 30+hp with those 4 mods. I went from 15.4 @90mph to 14.6 @96 for about $500 or less. Then a cam swap will help a lot, it's a lot of work, but I feel I picked up a lot of HP with it(Crane 2032 214/220 ~.500" lift)( and a siamesed base), I'll have real timeslips come friday, but so far I know I gained at least .2 sec and 1 mph(G-Tech). I think real gains will be more like 14.1 or 14.2 at 99 mph. all on stock heads in a 305.
Old 03-04-2002 | 04:51 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
The Tech Articles of this site are always a good place to start.
Old 03-04-2002 | 06:28 AM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
if you plan on sticking with the 305, a new set of world 305 heads will do wonders for the 305. If you can get a set of L98 aluminum heads, they would be nice too. You'll feel the biggest difference from a cam, but it is a lot of work to do it. A good days work to be exact.
gta90
09-15-2015 05:00 PM
TheExaminer
08-19-2015 11:07 PM
kyleb24
08-15-2015 09:24 AM
bradleydeanuhl
08-12-2015 12:48 PM
matthew911
08-12-2015 10:38 AM
