LT1 intake on a 350 TPI yes or no
Hey all i am new. I am Abe I have a 89 Iroc 350 tpi. The question is this. Will the lt1 intake work on my car, and is it worth it. Will gain gooh HP or should i just port the old one
Car: 1989 IROC
Go to www.lt1intake.com. John Millican has intakes already modified or you can send one to him to have it modified.
Tim
Tim
no its not to much trouble i jus installed it i bought it from john m and its pretty easy ill have pics shortly i love the looks i have it ready to but it snowed next day after i finished so im holding off for it to melt i would encourage anyone to install it lots easier than the stock tpi and super ram from what ive heard later
1 Post
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Originally posted by JucinGTA
No there is too much butchered modifications, Its not worth it you are better off going with a Miniram.
Page: Jmatlock he did it on his
Car: '99 HO Z28 / '03 Trailblazer
Originally posted by John Millican
I can't reply, I'm a little partial.
And if your car needs an EGR valve (smog check) you are SOL.
BTW there are dudes running 11's with the LTR (no power adder), go here and see
https://www.thirdgen.org/techbb2/sho...495#post537495
https://www.thirdgen.org/techbb2/sho...light=port+tpi
1 Post
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
if drilling out the distributor hole and mounting hole, filling the old bolt holes and drilling new ones, and redesigning ...
LT1 Intake Question:
What will the loss in torque and the gain in horsepower
( on a percentage basis) be from switching from a run
of the mill modified TPI compared to switching to the
basically stock sized LT1 intake that would replace it?
Does John Millican @ www.lt1intake.com do any
modifications to the LT1 Intake besides what
is necessary to convert from TPI, ie. enlarge the ports?
1 Post
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
He enlarges the intake port to take up to a 58mm. throttle body, which is a pretty nice feature! I plan on ordering one of his manifolda very soon, as soon as money permits!
1 Post
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Re: LT1 intake on a 350 TPI yes or no
BLUEIROC5.7, back to your original question. Yes the intake will work on your car, but as far as a huge hp gain, you need to swap heads and cam, to take advantage of the intake design. If you plan on modding the motor extensively it does make sense to buy the intake you will ultimately need. Remember, each time you swap out a component that is restricting airflow, look for next most restrictive all the way to the combustion chamber. With more air you also need more fuel, so that has to be included in the plan. Also, more mods dictate a change to chip parameters. Setting a goal for the car and balancing the mods is important to making you car fast.
Sanjay
08-12-2015 03:41 PM
