help me select a cam for my 383 afr lt1 intake motor
hi im building a 383 with 10.4 to 1 comression afr 195cc heads with compition port work 24 lbs injectors 373 rear gears 700 r4 tranny and putting LT1 intake on it i had the compucam 2032 in my ltr set up i loved it it was a 214-220 duration 496-510 lift with 1.65 rockers u think itll work good for me in my 383? i want good low end but want decent top end to thanks Ryan
Yeah it'll work just fine in your 383, with huge amounts of low end, but I'd personally go a bit bigger, your 383 will give you a big bump in low end torque from the extra stroke so you could easily move the torque curve up a few notches and still smoke the tires. The HOT cam is a good choice (and comparatively inexpensive at 175 from sdpc, or if you like the crane cams try part # 109821 which only bumps the exhaust duration up 2*, intake stays the same, but with your 1.65 rockers the lift would bump up to .537/.560. But its a little pricier. It's listed as for non-computer controlled engines, but with all the other stuff you'll need a reprogrammed prom anyway.
John
John
im building pretty much same setup, except with 23 trickflow heads,
383
lt1 intake
lt4 hot cam
its 5.10 lift now, does anyone know if i added 1.6 rockers what it would be then ?
383
lt1 intake
lt4 hot cam
i was jus on cranes web site thier 2050 cam sounds pretty good it is 218-218 power band is 2200-5800 heres the cam card
http://dab7.cranecams.com/SpecCard/D...1=Display+Card
Car: 91 Z/28
Engine: 6.3 L98
Transmission: TH350 4500 STALL
Axle/Gears: 3.73s
Hey supperrammed..Ihave almost the identical setup as you have in my 91 z..I have TPIS 's ZZX cam in my car ..It works awesome..Might be a lilttle to radical for some folks but not me..I have a 3500 Art car converter in my and the combo like i said is good..I do have a miniram so i dont have the low end that u will have, but the combo has netted me a best of 11.49 at almost 121..TPIS s ZZ9cam might also be a good choice for u..Anyways good luck
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
That ZZX cam is pretty damn big..... me likes, but rather $$$$ for me .... I think the LT4 HC is a dead ringer for that combo as it is fairly cheap and will work very well with that LT1 intake manifold. (I will hopefully be adding an LT1 intake to mine soon...)
