1985 TPI Fuel Rail test port size
Does anyone know offhand what size the pressure test port is on the fuel rail? I'd like to add a pressure gauge but will need to know the size to get the correct fittings! Plus... will it be possible to remove the pin from the test port? I appreciate your help!
Thanks!
Mike
Thanks!
Mike
Re: 1985 TPI Fuel Rail test port size
Thank you again.
Mike
Makes sense. So are there fittings available to replicate the fittings that are on the test gauges that are found at the local parts store chains?? Something that would depress the pin when installed. Then I would just make one I can use as needed.
Thank you again.
Mike
Thank you again.
Mike
https://www.ebay.com/itm/22382686510...mis&media=COPY
mcb55-210 (09-03-2024)
yes it’s an4, to mount a gauge it would be an4 to 1/8 npt elbow fitting .
Got it...and ordered!
Appreciate all your help!
Mike
omnipotentgoku
10-05-2006 05:42 AM
