Tuner Pro RT set up
Tuner Pro RT set up
Good Evening IROC MEN
I am trying to get a 1987 IROC back on the road, i had an initial tuner done by Brian from Tuned Performance, the car starts and runs and drives but does need an additional tune, having issues getting Tuner Pro RT set up to datalog. i would like to take the car to someone and have them tune it for me. i am getting no where with this set up for Tuner Pro RT. is there anyone in the Pittsburgh Pennsylivania and tri-state area of West Virginia and Ohio and Pennsylvania that can tune a thrid gen TPI IROC ??
Engine: L98 350 TPI
Axle/Gears: Borg Warner 9 Bolt, 3.27 gears
Re: Tuner Pro RT set up
I struggled to get it working but Brian (@Tuned Performance) was able
to revise the adx to $6e which is used in 1989 ecms and I was able to start data logging. Are you sure you have the correct adx for your ECM? Then did you follow the instructions.
Make sure to check the USB port you are using as well. To check the port your hooked up to, plug the USB cable in (do not connect to OBD port on car) then go to “Device Manager”. Look for “USB Serial Port” (see pic- mine shows COM3).
Then go to Tools- Preferences-Data Acquisition and Logging- Select Interface Type then select “Plug-I”. Click Apply Next click “Configure Plug In Component” Select the proper port (Mine is COM3)
Then go to #6 on instructions to load adx $6e file.
