Timing: where does the ESC Brown/White wire connect to?
Old 06-21-2022 | 04:34 PM
Rambler America's Avatar
Hello, I have read all the posting on setting initial timing and they usually say "disconnect the EST wire first before setting the timing, It's a single tan wire on the passenger side sticking out of the big wire harness near the A/C Canister" My 1985(?) Camaro TPI motor is in a 1959 Rambler so a lot of the harness has been rerouted/cut or covered up.
1. Does the Tan/white wire go into the HEI Distributor cap? (if so, I can make a disconnect there, pic 2)
2. I have this plug hanging around (pics 3 &4) any idea what it should connect to?
Thanks in advance, I have learned a lot on this site. I estimate this car/engine was put together in the early 1990s.
Old 06-21-2022 | 04:56 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Timing: where does the ESC Brown/White wire connect to?
Only a poorly educated guess but they probably left the connector in there to set timing in the first place. That engine isn't using a mass air flow sensor so the ecm is probably a 90-92 speed density unit. The tan/blk wire would go from the base of the distributor (not the cap/ign coil) to the ecm http://austinthirdgen.org/mkportal/m...ine_wiring.gif Follow the wiring, willing to bet the connector is still there.
Old 06-21-2022 | 06:09 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I’ve seen some street rod harnesses with est by ecm.
looks like a gauge connector. Like mentioned look gif the flat 4 connector off distributor and follow loom.
Old 06-23-2022 | 01:51 PM
Thanks for the replies, I started at the base of the distributor and was able to trace to behind the firewall to the connector. Success.
aliceempire (06-23-2022)
Old 06-23-2022 | 01:52 PM
Thanks, good advice, found connector behind fire wall.
zs&tas
05-31-2015 03:41 AM
rickeyhenderson
04-07-2012 09:31 PM
motorworld
07-21-2010 07:58 PM
LoudmouthSS
08-29-2005 09:45 AM
TransAmTBI
01-07-2003 07:47 AM
Quick Reply: Timing: where does the ESC Brown/White wire connect to?
