whining fuel pump
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
whining fuel pump
since i finally got the z back from the shop, i noticed that the fuel pump has a whining noise. if you listen to the c/k trucks, or astro and fullsize vans, they have the same noise b/c of the high pressure pump.
does anyone else's pump do that?
also what is the correct pressure it should be?
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
My new one does the same thing because they didnt reuse the pulsator thingy. Mine seems to vary though. Sometimes a quite whine sometimes a loud whine. I dont know if the varying loudness is normal or not.
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
Hey, if it works, don't worry about it. My black 86 IROC buzzes so lound you can hear it over the radio (till I start the engine). My red 86 IROC is so quiet I thought it was broke till the engine started and ran.
Listen to my Exhaust wav in my sig. Mine does the same thing.
92camaroJoe
08-13-2015 06:07 AM
