Lingenfelter tpi runners and plenum for 200 bucks..
A guy at work has lingenfelter tpi runners and plenum off of a corvette and wants 200 bucks for them i wanted to know if they would bolt onto my stock 305 intake base manifold.And is it worth 200 bucks?? thanks
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Re: Lingenfelter tpi runners and plenum for 200 bucks..
Seriously it will make your car slower, but buy it anyway. Let it sit in your garage until you get a 350, or sell it on ebay for $600+.
P.S. Very fishy to sell such a thing for so cheap, make sure the runners are very very big and FAT, and the plenum is also very very big and fat. Even if just the runners are fat and the plenum looks like stock.. that would still be a good deal.
how would that in any way make my car slower i already picked up the parts and the runners are very fat and the plenum is no where near stock.It will allow my motor to breath easier it will not make it slower.and i dont want to hear that 350 garbage i want a 305 so that when i beat the 350s i can laugh.
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
when you beat 350s they will think you have a 350 too no matter what you say. trust me I know.
around town the very large car gatherings i go to everyone knows i have a 305.so they will not even ask if its a 350 they already know its a 305 and besides even if they dont believe i know its a 305 and i can still laugh.
Car: 1994 Jeep Wrangler
can you say unbalanced? those intake parts will kill your low end tourque. that is a good price but it will make your car slower unless you do some major work. believe it or not. thats the same as saying that bolting on a 58mm throttle body onto a stock 305 will yield a performance gain. impossible
Now, I'm not saying that it will slow your car down, but I understand why some think it MIGHT. Unless your current runners and plenum are currently the biggest restriction, putting bigger ones on will only slow down the air velocity. Unless you've put in a bigger cam, ported cylinder heads, and headers, simply putting on a better flowing intake isn't going to help you.
Car: 1991 Camaro Z28
Why is your goal to beat 350s with a 305?
Will your goal next be to beat a 350 with a 4cyl? Displacement is not a bad thing....
Just curious as to why you think this way?
When I bolted a SuperRam on my mostly stock 350 I was VERY DISAPOINTED. After I ported the heads and put a cam in, the car was much faster, after I put the Cut-out on it will be even faster. What I'm trying to say is I put the SuperRam on a 357, and I wasen't happy...If you put it on a stock 305 (assuming your car is stock) I am positive you'll eather rip it off the next day or buy thousands in performance parts to balance out your engine.
If you don't believe us listen to the guy who invented it who says "Not recommended for unmodified 305 cid engines"
www.lingenfelter.com
My motor is stick not but i have other parts going on along with the intake i have slp headers,flowmaster cat back exhaust,high flow cat,and i am going to get some nice heads and a cam soon.with these mods it should help right????
Car: 1992 Z28 1LE
I think you should be alright considering that you do plan to do up the rest of the motor. Sure, on a stock 305, you would be wasting your money thinking that a ported plenum and aftermarket runners would yield gains.
I bought the Accel LTRs and Edlebrock base, BUT I didn't put it on until AFTER I did my cam and head swap (might as well considering the intake had to come off). The runners and base were sitting in my room for a year just staring at me, and I have a 350.
When I put it on my engine I had already gotten an expensive set of ported heads, full exhaust, a cam, and various other performance parts. It did not increase power over stock, in fact the car was slower with the super ram. If I were you I'd sell it on ebay for $600 bucks and use the profit to buy a 350 short block.
For the second time my car will not be stock.I am getting heads and a cam for it and i alrerady have a full exhaust on it.So i do not want to sell it i will put it on the MODIFIED 305 and see what it does.
Sanjay
08-12-2015 03:41 PM
hiflow, homemade, intake, l98, lenginflter, lingelfelter, lingenfelter, manifold, plenum, port, runner, runners, superram, tpi, tune
