Holley Throttle Body 58MM LT1?
Old 01-08-2018, 01:27 PM
JuanZ28's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 5.7 TPI
Can I make this work for my 1987 5.7 TPI. It does not have the same linkage.
New Throttle body 58MM
Old Throttle body. 1987 TPI 5.7
Attached Thumbnails Holley Throttle Body 58MM LT1?-20180108_083325.jpg   Holley Throttle Body 58MM LT1?-20180108_082948.jpg
Old 01-08-2018, 04:22 PM
TGO - 10 Year Member
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Holley Throttle Body 58MM LT1?
If you use a 89-92 f body throttle cable it might work. You will also need to change the tps connector . The iac plate will work from the 87 throttle body.
Old 01-08-2018, 04:43 PM
JuanZ28's Avatar
Engine: 5.7 TPI
Thanks Tuned Performance. Good chance I'll sell it better.
Old 01-08-2018, 07:20 PM
ULTM8Z's Avatar
How much would you want for it?
Old 01-09-2018, 07:30 PM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/engi...body-58mm.html
The Project
11-25-2007 10:40 AM
87frankenbird90
04-16-2007 07:39 AM
rosco88ta
01-17-2007 10:18 PM
Smokin87TA
07-26-2006 10:07 PM
Wayquick4u
02-06-2001 09:42 PM
Quick Reply: Holley Throttle Body 58MM LT1?
