Help Identifying Holley Throttle Body Year
Old 12-24-2017, 05:09 PM
Mr. Notorious's Avatar
I bought this Holley aftermarket Throttle Body many years ago and I was asked if it would bolt onto a '89 car.
I don't see where the typical Holley112-xxx part number is stamped on here. The only numbers appear to be "11323 1 161 5"
Does anyone know if this will work for all years TPI? Or what should I look for to distinguish the years?
I plan on calling holley on Tuesday when they open, hopefully they're not shutdown for the holiday.
Thanks!
Old 12-24-2017, 06:22 PM
TGO - 10 Year Member
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Help Identifying Holley Throttle Body Year
89-92 linkage but the iac passage does not connect between the bores. A hole needs to be drilled in the plenum or connected between the throttle bores. I’ve ran into this on a few holleys
Old 12-25-2017, 06:56 PM
Thanks for the reply, I'm not entirely clear about where the drilling would need to occur.
I do see a coolant passage between the two bores in the plenum, is this good?
Would someone be able to use PAINT or something to sketch where the drilling would be needed?
Old 12-25-2017, 10:12 PM
Engine: Lb9
Transmission: M20
That’s a older 85-88 plenum it will work as is.
camarofan411
06-04-2015 01:53 PM
dredre08
04-01-2011 09:48 AM
amichals
10-22-2008 03:29 PM
Quick Reply: Help Identifying Holley Throttle Body Year
