think I found my vacuum leak...
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: think I found my vacuum leak...
This info may not be helpful to you since my vehicle is a SS Monte Carlo with 350 TPI. But on my swap that vacuum line goes to the HVAC vacuum line and the vacuum ball.
Car: 1987 Trans am GTA
Engine: 5.7 liter
very possible considering one vacuum canister is on the trash with a hole in it and the new one is on a shelf...
Engine: 5.7 liter
yeah, the whole vacuum system on this car was/is a mess. the vacuum lines and the windshield washer lines were all mixed up, I got the washer lines straightened out but there appear to be to many check valves and to many T's. I'm thinking I may be better off taking all of the vacuum lines out and starting all over
Engine: 5.7 liter
thank you, I was actually on the vacuum diagram trying to print this off while I was at work
