305 TPI 1227165 $6E ECU idle function
Hello
It was not possible to find some detailed information how idle control works for the $6E Version.
I use Tunerpro for diagnostics and tuning and i use the file expanded.dxf
What i know.:
Idle:
Engine RPM starts with the IAC Park Position. Then the IAC moves to a second position near the desisignated idle RPM (what table is that ?)
Then the Idle function starts to control rpm (Idle RPM vs. Collant).
What Table is the input for that second position of the IAC ?
Follower:
If you hit the gas another function is adding steps to maintain driveability (steps added to Throttle follower in drive)
The following tables and scalars are of interest:
-Warm IAC Park Steps vs. Coolant(0x588)
-Idle Speed Time Out IAC Steps vs. Coolant or MAT(0x59F)
-IAC default keep alive motor Steps(0x597)
Which table is the baseline and how are the steps calculated when the car is moving ?
Are there other parameters to look at ?
Thanks a lot (please forgive me my bad english).
What i know.:
Idle:
Follower:
Re: 305 TPI 1227165 $6E ECU idle function
Hello
What i know.:
Idle:
Follower:
What i know.:
Idle:
Follower:
My interpretation is slightly different. Upon powering the ignition, the IAC starts by following the "Idle RPM Startup Position" commanded number of steps. There is a brief "Idle Speed Start-up Delay" timer which should keep the IAC in that position until the engine RPM is above the parameters set for "Stall Saver Spark Enable Threshold" settings. Once the engine RPM is above that limit the parameters set by the ""Idle RPM vs. Coolant" will set the base target idle RPM, and several parameters can add to this base number, such as "Idle Speed Adder Park/Neutral" "Idle Speed Adder A/C Enabled" "IAC Steps for Warm Park" and "IAC Steps for Fan Anticipate" as well as "IAC Steps for Drive."
There are various parameters for deadband or tolerance for some of these RPM adders, so verify that the RPM deadbands are not set much above 30 RPM.
Thanks for that answer. My problem is the following.:
Engine is warm and i start the engine. In this moment the RPM goes up because of the value "IAC Park Position" (in my case 80 Steps), than 1s later the IAC moves to the value in the table "Warm IAC Park Steps vs. Coolant or MAT" (in my case 50 Steps). Then the System should begin to idle at the defined speed "Idle RPM vs. Collant" (in my case 688 RPM) but it doesnt ! The desired Idle speed of the system is about 850 for ~ 40s in D, then the system comes down to idle.
The problem is that i dont want to wait so long, and i start to drive when the RPMs are at 850. In this case the IAC is about 50 Steps (but it should be 10 Steps at 688 RPM). This leads to a very high base RPM while driving. The only way to come down is to stop and let the idle learning work.
I hate this logic ! Is there a parameter to come down quicker ?
I dont know where the 850RPM are coming from ?????
Is it possible to drive without IAC ?
Unplug the valve and set Idle with the Blade itself.
Instead of disabling the IAC, it may be very useful to check/set the throttle minimum air position. It is possible the TB is worn or has alignment issues, and that the stop screw may have been moved. Clean the TB bores and plates (front and rear) and set the position:
Throttle Minimum Air Position
Tools needed:
1. Torx driver # T-20
2. Paper Clip
3. Small Punch
4. Tachometer
GENERAL NOTE: The engine should be at normal operating temperature before performing any adjustments. Never rely on the dash mounted instruments for diagnostics and adjustments. The oil pressure and temperature gauges and the voltmeter and tachometer just aren't calibrated accurately enough for diagnosis, but are a relative indication for monitoring the vehicle while driving.
For this adjustment, the transmission will be in DRIVE while you're under the hood. You will need to securely set the parking brake and block the drive wheels. It would also be a good idea to have an assistant hold the service brakes while you perform the adjustments.
In order to successfully complete the adjustment, the IAC air passages and pintle need to be clean. The throttle plates and bores need to be clean as well. If this is not the case, you'll need to remove the air cleaner from TBI engines or the intake air bellows from TPI engines to gain access to the area to be cleaned. A spray-type carburetor cleaner works well for this. Cleaning the IAC passages on a TPI/MAF engine will set a DTC, but we'll be clearing that later. With the engine idling, direct the spray cleaner into the IAC air passages and around the throttle plates. Shut off the engine and continue cleaning the throttle plates by opening the throttle manually. Once everything is satisfactorily cleaned, replace the air bellows on TPI engines. Many times, this alone can solve IAC/idle speed problems.
If this doesn't solve the problem, you may need to remove and clean the IAC stepper motor. If the IAC appears to be clean and functioning properly, continue with the adjustment procedure.
Idle Air Control Cleaning
You can remove the IAC and service it. Remove the electrical connector from the IAC. Unscrew the IAC unit from the throttle body.
You can gently rock the pintle back and forth and allow the spring to extend it until it comes apart in your hands. Clean everything with lint-free cloths and a mild solvent. Harsh solvents can affect the insulation of the stepper motor coils. It's generally the dirt and buildup on this worm shaft that causes sluggish IAC operation.
When the worm gear on the pintle shaft is clean and dry, apply one drop of clean light oil to the shaft. Measure the free length of the spring, adn stretch it carefully if necessary to make the free length at least 2¼". Assemble the parts in proper order, start the pintle shaft into the stepper motor in the correct orientation (paying attention to the keyways), and work the pintle back into the rack gears of the motor by the same rocking motion. It takes a while to get the pintle back into the worm gears, but you'll get it. It is important to get the pintle fully retracted into the housing so that the pintle is not forced against the gears when reinstalling the IAC unit in the throttle body.
While the IAC is out, clean the air passages in the throttle body. The oriface in the TB where the IAC resides is the seat that the IAC valve closes against, and it can accumulate a lot of carbon, dirt, and debris. The easy way to do this is with carburetor cleaner and a small stiff brush.
When everything is clean and dry, replace the gasket if it is damaged, apply a little anti-seize to the threads, and torque the IAC to the proper specs. (13 ft/lb for '85-'89 , 30 in/lb for 1990-on.) Proceed with setting the TPS and minimum air position.
Locate the Assembly Line Diagnostic Link connector under your dash panel. Remove the cover if it is still there.
Cut and form a paper clip into a "U" shape. Insert the clip ends into the ALDL in the 'A' and 'B' sockets.
Turn on the ignition, but DON'T start the engine. This will force the ECM into its diagnostic mode. Wait 30 seconds to allow the IAC pintle to fully extend. With the ignition still on, go under the hood, remove the electrical connector from the IAC, then turn off the ignition and remove the paper clip jumper from the ALDL. With the IAC pintle fully extended (closed) all idle air will be controlled by the position of the throttle plates. Some manuals indicate that the EST bypass connector should be disconnected for this procedure, while some make no mention of it. While timing is a factor in idle speed, the EST should only operate as a function of engine RPM, temperature, and detonation sensor inputs. To remove all doubt, disconnect the EST bypass connector is your car is so equipped. Some TBI and V-6 engines do not have this bypass connector, and therefore must be set with no regard to the EST system. The EST can be bypassed on some cars by grounding the diagnostic terminal at the ALDL and continuing with the procedure, but the fuel mixture will be skewed to the rich side, affecting idle speed as well. In any event, the minimum air position idle speed range is wide enough to allow for some variations. As always, it is best to consult your service manual for the exact procedure for your system.
Locate the Torx screw on the left side of the throttle body. It may be equipped with a protective metal cap from the factory. This was intended to discourage adjustment. If the cap is present, use a small punch to knock it out. Once the screw is accessible, start the engine and place the transmission in DRIVE. Adjust the throttle stop to obtain 400-450 RPM with the transmission in "DRIVE" on an automatic transmission car, 450-550 in neutral on a manual transmission car, rotating the Torx screw clockwise to raise speed and counter-clockwise to lower speed. Once the idle RPM is set, place the transmission in PARK and turn off the engine.
Re-connect the electrical connector onto the IAC. Start engine. Idle speed should be governed by the ECM at approximately 600-650 rpm in "DRIVE" (for unmodified cars). Idle speed in NEUTRAL or PARK is less significant, and will be higher.
Throttle Position Sensor (TPS)
Tools needed:
1. Digital Volt-Ohm-Meter (VOM)
2. Breakout jumper wires or probes (make your own)
3. AutoXray, Diacom, or similar scanner will replace the VOM and jumper wires.
Turn on ignition, but don't start the engine.
With a diagnostic scanner: plug in the scanner and read the TPS voltage. It should be 0.54Volts +/- 0.07 VDC.
Connect the VOM to the TPS electrical connector terminals ‘A' and ‘B'.
With a breakout jumper: Disconnect the electrical connector from the TPS. Install the breakout in-line, between the TPS and wiring harness connector. Connect the meter probes to terminals 'A' and 'B' on the connector. (‘B' is the positive connection, ‘A' the signal ground, or negative.)
With probes: If you have very slender probes on your VOM, you can back-probe the TPS connector while it is attached to the TPS. If you have made probes of large dressmakers pins or a similar item, you can back-probe the connector as well. Connect the meter probes to terminals 'A' and 'B' on the connector.
Turn on the ignition to read the TPS output voltage at the idle position. The reading should be 0.54VDC +/- 0.07VDC. The ideal is the center of the range, 0.54VDC for a stock engine. To adjust the output voltage, loosen the two Torx screws holding the TPS to the throttle body, and slightly rotate the TPS up or down, reading the voltage until it comes into specification. Tighten screws. Using the throttle lever, rotate the throttle to WOT (wide open throttle). The TPS voltage should be over 4.0 volts. Close the throttle again, and then slowly open it to WOT, observing the voltage reading. It should increase progressively and in a linear fashion. If it sticks or jumps or falls off at all while doing this check, the TPS sensor may be failing and could be a cause of stumbling and driveability problems.
After achieving the desired setting, turn off the ignition switch. Remove all jumpers or the scanner and reconnect the TPS connector as required.
Reinitializing the ECM
If you set a DTC during the procedure, the SES light should be illuminated on the dash. This ECM retains DTC data for the previous 50 engine starts, so the codes will eventually be cleared. If you want more immediate results, after shutting down the engine disconnect the negative battery terminal for five minutes. This will clear the ECM of all diagnostic trouble codes. Clearing the ECM also clears any data learned about your engine, and clears the radio presets. If you have a Delco-Loc or Theft Loc II radio, make sure you follow the procedure to unlock the radio protection before disconnecting the battery. This five minutes is also just about long enough to clean both battery cables. Reconnect the battery. When you first start the engine after clearing the ECM, the engine will operate with base parameters programmed into the ECM PROM. These parameters may not be optimum for your engine, but the ECM will enter a Block Learn Mode soon after the engine is warm and enters Closed Loop Mode. The ECM will write new data tables specific to your engine and will eventually rely on those tables instead of the base tables of the factory program. You can expedite this process by driving the car for 20 minutes under varying conditions to allow the ECM to initialize. Or you can wait and drive the car normally at your convenience. The BLM tables are constantly being updated as sensor input ranges change, but the greatest change will occur within the first twenty minutes of Closed Loop operation.
Tools needed:
2. Paper Clip
3. Small Punch
4. Tachometer
Tools needed:
