Falls flat at 4k rpm...need advice
Old 03-30-2017, 02:07 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Axle/Gears: ls1 rear with 3.23
Got a tune on my 383 tpi. Falls flat around 4k..tuner at dyno Shop in Santee ca said it most likely is air flow issue. They did multiple hits with different timing and advance and nothing solved it.
any ideas?? Or is this a common tpi style intake issue.
383 sbc, 218/226 cam, tpis base, siamese runners, stock tb,
Old 03-30-2017, 02:11 PM
TGO - 10 Year Member
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: Falls flat at 4k rpm...need advice
I have never seen a dyno graph drop like that at 4200! Wow. Did it drop a cylinder or 2?
Or did the nitrous turn off? Lol
Old 03-30-2017, 02:36 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
I have no idea. Lol. It's making me mad. Had a couple hits at CCC motorsports in lakeside a few months ago..graph was wayyy smoother. Not sure what the deal is
Old 04-01-2017, 06:58 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Any ideas?
Old 04-01-2017, 07:24 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
maybe valve float issues?
detailed cam and spring info might help the engine guys?
Old 04-03-2017, 02:31 PM
86Z
86Z's Avatar
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
knock retard?
Old 04-03-2017, 02:52 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Originally Posted by 86Z
knock retard?
we tried multiple knock settings in the holley efi program. Nothing worked. We also tried no knock sensor at all. Still nothing.
cam is 218/226 , 0.462 int./0.470 exh. And 112 lsa.
Could this be an issue with the stock throttle body?
or tpi intake altogether?
Old 04-03-2017, 02:53 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
how would I check for valve float?
Old 04-03-2017, 03:09 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
you need a spring pressure tester. are you running the stock springs or new ones recommended for your cam?
http://www.sbintl.com/tech_library/a...alve_float.pdf
Old 04-03-2017, 05:48 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Ignition issue? Was it a problem with the dyno signal pickup or something?
Valve float usually acts like a wavy erratic line and not a big drop off like that with it continuing to climb again.
Almost looks like it dropped a cylinder or two
Old 04-04-2017, 01:34 AM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Absolutely nothing common about that. Don't blame tpi for that.
Old 04-04-2017, 04:51 AM
Street Lethal's Avatar
You already said you made a previous hit that was way smoother, so how could it be the stock throttle body or TPI intake altogether? Anyways, looking at the graph it looks like you slapped a TPI system w/siamesed runners onto a modded 383 w/stock L98 bin. Meaning you are tuned up until 4000-RPM, then the increased airflow comes in, airflow in which you are not tuned for, and power drops eventually catching itself. You said you made multiple timing changes, but where? Did you at least tune the SA Main Table, or were you referring to just Base/Idle SA? What was the air/fuel throughout the pull? Can we see a copy of the bin? Information like this will immediately pinpoint what is wrong.
Old 04-04-2017, 02:04 PM
Abubaca's Avatar
Car: 2016 Camaro SS + ???
I'm also running a 383 with ported TPI, similar cam, but more lift, and I'm also running Holley HP EFI. I'm pulling strong to about 5500. haven't dyno'd yet since the self tuning went well, and I've just start dabbling into ME tweaking the tune a bit to find power. I was hoping that a dyno tune would be my last step. ...but I can tell you I don't have any power drop like what you've posted. Heck I don't think I've ever seen a 200 RPM drop like that!
What is your datalog showing you? What about fuel pump/pressure? New pump? You keeping pressure all the way through the run? What are your fuel compensation table values right before you drop off that cliff?
I don't have NEAR the engine building experience some of these guys do, but I just cranked my engine this past December, and I'm also using the same engine management/Holley HP system. V E R Y Familiar with the ins and outs at this point!!!!!!!!!!!!! I'm very happy to help!
Old 04-04-2017, 02:45 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Just thought of this...was the torque converter locking at this point
Old 04-04-2017, 05:12 PM
Engine: LB9
Axle/Gears: 3.08
What injectors/fuel pump?
If the dyno has the original file have them pull up the AFR graph for you.
Looks like a fueling issue to me.
Old 04-04-2017, 06:59 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Walbro 255. For red top 30#
Old 04-04-2017, 07:04 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
I wasn't there for most of the tuning. And I know very little about it. Getting a laptop this month so I can try and learn. The bin is the Spark Advance table?
Old 04-04-2017, 07:05 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
trans is supposed to have transgo hydraulic lockup. Not sure honestly.
Old 04-04-2017, 07:06 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
how do I check for dropped cylinder?
Old 04-04-2017, 07:08 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Springs/lifters from crower for cam
Old 04-04-2017, 08:00 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Guess inspect the spark plugs on the pull, heat gun on the cylinder headers to check for cool tubes compared to the rest.
Make sure the plug wires are good and distributor is good. Ignition module/cap/rotor etc
What spark plug gap? What plugs?
Old 04-04-2017, 08:03 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Reason i ask is the stock bin has a setting to lock converter at wot. Somewhere around 88 mph. Usually drops the rpms/slows the pull down abit at that instance, but power usually goes up as there is no loss of power in the converter slip with the converter locked
Old 04-04-2017, 08:30 PM
This is what I think the problem is. Not taking anything away from that dyno shop that did the tuning, but I am almost convinced they missed something in the tune, or at the very least inadvertently made a change that they cannot find. It ran fine, you got a tune, now it falls flat on its' face. Bad tune, tuner can't find what's wrong. Get a copy of their tune asap.
Old 04-04-2017, 08:44 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
cap rotor coil all replaced during testing. Ac Delco 6
Old 04-04-2017, 08:46 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
No I don't have converter harness even installed for computer to control lockup so I don't think it's that.
Old 04-04-2017, 08:52 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
let me rephrase. Tune at CCC motorsport was bad. Misfires on half and quick full throttle, very hard starts, and high erratic idle. They said misfires could be stock fuel pump because the fuel pressure was dropping slightly. I replaced with a 255lph. Still Misfires. Fast forward to now. Took it to DynoShop in Santee. No Misfires, good idle, altogether smoother running engine, but power drop issue
Old 04-04-2017, 09:07 PM
Abubaca's Avatar
Which Holley EFI are you running???
...almost everything we're discussing can be diagnosed/crossed off the list by having access to a laptop hooked up to the ECU and data logging. Are you paying this shop to pull a dyno run, or to TUNE the car???? ....if they're tuning, I'm surprised they can't SEE what's happening on their datalog. ....and if the engine didn't fall on it's face BEFORE you brought it to them, and they smoothed out the idle etc. etc, but now it's falling on it's face.....it's gotta be their tune!
Old 04-05-2017, 12:48 AM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
it never ran good enough for me to tell after the first tune from CCC motorsports. The graph on the printout they gave me had a nice looking, smooth curve. Must have been bs. I'm buying a laptop this week so I can learn and look at everything that was said here.
I paid the shop for the tune. They said "they can see everything when tuning" and couldn't figure it out.
Running holley hp efi
Old 04-05-2017, 07:20 AM
Abubaca's Avatar
I think getting that laptop is key. Nothing like being able to invest your own time into it. While I'm no tuning pro, I'm very familiar with the Holley HP, and I can help you out a good bit getting things going. The amount I've learned just in the last 4 months of having mine running is amazing.
Just to be clear, I'm not discounting anyone elses knowledge or opinion as to what your problem is. MY point is that once YOU are familiar with the system and have all the data on your laptop in real time, I think YOU can figure out a lot of what's going on, rather than simply pay someone else, and still not have your problem fixed. Then when you DO come onto this site, you can better answer some the questions these guys have.
We'll get you going!
Old 04-05-2017, 07:36 AM
Abubaca's Avatar
In the meantime, get the Holley software loaded on your PC. Honestly if I were you, I'd start over completely. Obviously you can't tune from your PC, but you can slowly go through it step by step and set up basic tune parameters for your engine. Fuel injectors, offsets, displacement, ignition, and a host of other little things. Plus you can learn all the different tabs, screens, tools, etc. etc.
...then....once you DO get it loaded on your laptop and ultimately into the car, you're already familiar with the software. The system does a decent job of self tuning, but you gotta have that base calibration set up properly.
The self tuning won't tune as well as a professional tuner could, but it should do well enough to determine if you have mechanical issues or tune issues. You can get that worked out on your time, with no extra costs (hopefully). Then you can do as much or as little performance tuning on your own, and then of course you can STILL always take it to a professional shop. That's been my plan, and why I chose the Holley. Thus far it's working well for me.
