Removing cylinder heads without emptying A/C?
Car: Camaro Iroc-Z -89
Transmission: Automatic
Hello!
Is it possible to remove the cylinder heads without emptying the A/C system?
According to my repair manual (Chilton's) it seems so but I'm not sure. Reason for doing this is unfortunatly that I need to "refurbish" my cylinder heads because of leaking valves.
Thanks for your help!
BR,
Per
BR,
Per
Transmission: T-5, TH350, T-5
Re: Removing cylinder heads without emptying A/C?
Yep. It's easy to do. Disconnect the compressor from the accessory bracket but do NOT disconnect the lines from the compressor. Just move the compressor to the side, the lines will give you a bit of room to move.
Ward
04-05-2001 07:17 PM
