replacement molded PCV hose
1 Post
Car: 92 Firebird Convertible
Engine: 383 - First Fuel Injection TPI
Axle/Gears: 3:23
Re: replacement molded PCV hose
This is from a GM parts book:
Item 32 - Hose. CR/case vent VLV - 14088538
Hope this helps.
Hope this helps.
1 Post
Axle/Gears: 3:23
Got a CD from this website - well worth the money.
https://www.78ta.com/store/product.php?productid=131
I replaced the engine (383) and converted my 1992 Firebird convertible from TBI to TPI (a First Fuel Injection unit from Bristol, WI)
Is that rubber or the harder nylon type material?
There are a lot of vehicle-specific hoses (Dorman 46033 in rubber, 46046 in a plastic) that might work, assuming you don't find a third-gen specific piece. And the plastic ones are fairly easy to heat up and bend with a hair dryer or heat gun. Good luck finding it.
Found a used one:
https://www.vette2vette.com/?q=produ...-valve-hose-lh
firebirddude142
09-23-2015 11:36 AM
