91' 350 wont run
Old 05-01-2015 | 04:16 PM
ryanp's Avatar
91' 350 wont run
hello all, tried starting my 91 z28 and now cant hear the fuel pump prime. car has been sitting, but turns over fine just never starts. checked fuel relay and fuse block by the battery and all is good. I did notice that the security light on the display does not go out. Maybe vats issue? This doesn't help much but car will start with starter fluid. Any help is much appreciated.
Old 05-01-2015 | 09:53 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: 91' 350 wont run
Might be vats. Ifyour relay and your fuse is good next is to test power going into the tank to rule out fuel pump failure
Jake_92RS
01-28-2020 10:37 PM
theshackle
03-05-2017 06:37 PM
NWAsonoma
08-18-2015 05:45 PM
bamaboy0323
08-15-2015 07:20 AM
BBSDesigns
08-11-2015 07:39 PM
Quick Reply: 91' 350 wont run
