Hard starting
Car: 1986 camaro iroc z28
Hard starting
Hi new to this but here I go.Just bought 86 i-roc with 305 TPI engine it starts good when it cold but after you drive it for a bit and shut it off and go to start it its hard to start.It will crank over for a bit then start and will run rough for a second or two
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Hard starting
hello, and welcome.first,check your codes.is your check engine light on when its running? second, if youre serious about driving it AND you don't want to go insane.buy a FACTORY SERVICE MANUAL!! in it you will find a wealth of information. NOT a chiltons. NOT a Haynes manual. and thirdly, stay far ,far away from auto zone, they are not your friends.
92camaroJoe
08-13-2015 06:07 AM
