Major rough idle
Car: 87 Iroc
Engine: 5.7L TPI
Transmission: Built 700R4
Axle/Gears: 3.23 posi
Major rough idle
My adventure started on tuesday when i was driving to school. it started running rough and progressively got worse as i kept driving. by the time i got to school and parked (about 5 minutes/1.5 miles) it felt like it was running on 7 cylinders. i thought it could have been a burnt spark wire so i checked them right then and nothing, they were all well clear of the manifold. After class i started it up and was heading out of town and was running just fine. i hit the bridge to go over the river (about 5 minutes/1.5 miles) it started acting up again. Considering it was 12 miles to the other campus i immediately headed back home. I checked wires again and more thoroughly, but still clean. I checked connections on the wires both at the dizzy and the plugs, all were good. I checked, cap and rotor, pickup points, coil, plugs, and wires. I ended up replacing the distributor because i thought it was pickup points (came with ignition module). Still runs like poo. when first fired up it will run just about perfect then will get progressively poopier. I threw the stock chip back in it thinking my burnt chip went bad and it took longer for it to turn poopy but ended in the same result. Driving it would start good and get worse by missing under load then going to missing under any load(holding 50 mph was hard)
As it is right now, i have reset the timing and it initially starts and runs good, then as it idles down it will miss pretty hard and just rough generally rough. It will die within a second or two of putting it in gear and haven't been able to take it for a test drive. I verified that the rotor was pointing at the #1 spark plug at TDC. I have a datalog of when i had it out earlier if anyone is interested.
I have tested/replaced:
Fuel pressure (42 KOEO/32-34 running with vac)
Coil (known working from another motor)
Pickup points (tested and now new)
Wires (new a month ago)
spark plugs (new a month ago)
injectors (south bay bosch III's in december)
Compression (160-150-150-150-155-145-150-150-150)
fuel filter (new)
Distributor (new)
Ignition module (new)
O2 sensor
I might have forgotten something, its been a long three days...
Thank you for reading my rather long winded post, i wanted to give as much information as possible. The car is an 87 iroc 5.7 tpi 700r4
fuel filter (new)
Distributor (new)
O2 sensor
Car: 87 Iroc
Engine: 5.7L TPI
Re: Major rough idle
Thank you for the reply, i will try that when i get back from class.
If it fixes it does it mean the O2 sensor is bad? I did replace it with another O2 i had.
Car: 87 Iroc
Engine: 5.7L TPI
disconnected the O2 and no change. I just ohmed all the spark plug wires and the injectors and they all checked out. Are there any ideas? Things to check? i am out of ideas
Car: 87 Iroc
Engine: 5.7L TPI
I tested fuel pressure yesterday. 42 psi with Key on engine off. 32-35 running at idle with the vacuum reference hooked up. pressure rose with throttle input up to around 45. i believe it was 45 without the vacuum hooked up. with as tight as i could clamp the return line (don't have vise grips) pressure got to 70
Edit: i found a portable vise that i could clamp the return line good and tight. still only reached 70 but i saw it was bleeding down pretty quick.
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Next comes a fun one..... is the EGR valve sticking open? Solenoid bad? (disconnect vacuum from solenoid, see if things smooth out.)
Getting any black smoke while idling?
Car: 87 Iroc
Engine: 5.7L TPI
i haven't had EGR hooked up in.... 4 or 5 years. Any way it could magically open itself?
Engine: 5.7 TPI
Not that I am aware of...... (I have tried waving my magic wand REALLY hard, and it just didn't make any difference at all..... bummer. )
Got a spare ignition module to toss into the dist?
Car: 87 Iroc
Engine: 5.7L TPI
The ignition module is the first thing i replaced. got a new Echilin one from napa and threw that in there, no change. and I have the new one that came on the dizzy on tuesday in there now. I returned the one from napa (shhh! don't tell them i installed it) so i just have the original one that was on it when the problems started.
Engine: 5.7 TPI
It sounds like something is getting hot, and failing.... but, you have been thru all the usual suspects..... if you have a MAF sensor, let the engine idle, and whack the maf with a screwdriver handle. See if the engine stumbles.... either that, or disconnect it, and go for a ride.....
Car: 87 Iroc
Engine: 5.7L TPI
I disconnected the MAF but didn't even put it in gear because it was running so bad.
Car: 87 Iroc
Engine: 5.7L TPI
Car: 87 Iroc
Engine: 5.7L TPI
Car: 87 Iroc
Engine: 5.7L TPI
The fueling is running pig rich. Had blm's right around 128. I had a wiped cam lobe suggested to me so I will test that when I get home
Engine: 5.7 TPI
Have a look in the log at line 2904-5... Things freak out at that point. Battery voltage goes to zero, engine RPM goes to zero, IAC cranks itself wide open, etc..... wonder why....
Car: 87 Iroc
Engine: 5.7L TPI
2904= Engine turned off, keys thrown on the counter, and a Pepsi taken out of the fridge
Car: 87 Iroc
Engine: 5.7L TPI
Well its not the cam... i am pretty sure it is either spark or injectors
it's unusual for the bosch lll's to have problems unless there is some debris in the injector. We have never seen one with a bad coil. If you want, send them in and we'll be more than happy to test them for you. Let us know.
Car: 87 Iroc
Engine: 5.7L TPI
I will pull them out today and see if I can find any obvious restrictions and let you know. Thanks for the reply!
Car: 87 Iroc
Engine: 5.7L TPI
Well after taking the plenum and fuel rail off and visually inspecting and ohm-ing each injector, I now have a couple new symptoms. Turning the key on I can hear the fuel pump priming but I walk around the front I barely get any pressure out of the fuel port. I tested the car before I took it apart and it started and ran just fine but with the usual miss. It is now starting very hard and running around 2000 rpm then promptly dying. I managed to catch it and throttle it by hand and it sounded baaaaad; It didn't want to run. I thought of air in the fuel rail but it should clear out in the return line after the first, maybe second prime correct?
Car: 87 Iroc
Engine: 5.7L TPI
The engine is clearly struggling to turn over one piston when starting so in my continuing suspicion of a leaky injector, i pulled the fuse to the fuel pump to prevent priming and tried starting the car. The first time it clearly stressed over the one cylinder, fired once in each cylinder, and immediately died. the second time, figuring leftover pressure and fuel were gone, i tried starting it again and it turned over how it should nice and easy.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Car: 87 Iroc
Engine: 5.7L TPI
Ended up being a leaky/failed... injector. I got and installed the old injectors today and it runs perfect again!!! thank you everyone for your help and input!
