custom fuel lines
Car: 91 Camaro RS
Engine: 305 TPI conversion.
custom fuel lines
I want to replace my fuel lines starting from the metal lines on the driverside wheel well to the fuel rail on the car. has anyone done this? im not sure what size fittings are on both lines. I was looking at the 2 foot premade lines from jegs or summit.
Car: 92 Z28
Engine: Boosted LSX
Re: custom fuel lines
These Guys have what you need also. Good people to buy from
9894DBH Female 14mm x 1.5" to -6: Fuel Injection Female "O" Ring Seal
9894DBJ Female 16mm x 1.5" to -6: Fuel Injection Female "O" Ring Seal
The 14mm would be for the return side, while the 16mm is for the feed side.
http://stores.ebay.com/Nook-and-Tranny-LLC
http://www.nookandtranny.com/
Dug up some old links for ya..
https://www.thirdgen.org/forums/fabr...teel-fuel.html
https://www.thirdgen.org/forums/memb...y-start-3.html
post below is directly from the link i provided
Earl's #361-9894DBH # Fuel Injection Female O-Ring Seal 14mm x 1.5 Thread (Jegs $11.99 )
Earl's #361-9894DBJ # Fuel Injection Female O-Ring Seal 16mm x 1.5 Thread (Jegs $11.99 )
Earl's #361-310006 AN Size: -06 (3/8''); 10' Foot Length (Jegs $52.99) - NOTE: You wont need more then 6 feet
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I would look on some of the truck parts sites like LMC. Some of the 88-95 fullsize Chevy/GMC trucks with TBI came with stainless braided fuel lines from the factory. They are more than long enough, the same diameter/fittings, and probably cheaper than aftermarket.
theshackle
03-05-2017 06:37 PM
LT1Formula
20
11-14-2015 12:02 AM
AkDrifted
08-17-2015 07:45 PM
