Burned out connector
Old 04-09-2014 | 02:13 AM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
I saw this burned out connector and cannot find any info on it. The only thing I can find in the service is it is Connector C115 (I think). What do you think it is?
Old 04-11-2014 | 02:27 AM
Veaceonee's Avatar
Re: Burned out connector
anyone?
Old 04-11-2014 | 11:37 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
I have a different vehicle, but based on the location it looks like it might be the Power Lead for the High Speed Blower relay on your HVAC. If so, it should come directly off the starter, through a fusible link, to the connector, and then to the high speed relay. At least on the G-bodies, they are very prone to melting like that. Poor connection in the connector, or too high a draw from the old blower motor.
Old 04-11-2014 | 06:52 PM
Veaceonee's Avatar
Could it be a sign the blower motor is going out?
Old 04-11-2014 | 11:29 PM
darbysan's Avatar
Old motors have brushes that are worn. A new blower is only about $20. A poor connection anywhere in the circuit can also add resistance, causing higher amperage draw. Usually it is a combination of poor connections and old motors.
F.I. 57 Belair
08-23-2021 01:09 AM
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
91 SrS
10-07-2015 04:32 PM
meeklay812
10-01-2015 03:46 PM
RS Reaper
09-27-2015 07:04 PM
Quick Reply: Burned out connector
