mega squirt vs fast ez efi
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
I see a lot about MS but not much about F.A.S.T. EZ EFI. I have a buddy with 1 but he never had MS.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Re: mega squirt vs fast ez efi
I prefer the Holly Hp systems extremly user friendly and the best help buttons that will teach you tuning if you didnt know
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
While I love my MSII but I will say it has a fairly steep learning curve. If you like to tinker then it is the system for you. If you want to set it and forget it then probably not.
Just out performance is one better than the other.
Car: 85 Trans Am
I doubt performance is really an issue here. I'm sure they will all perform equally as long as the tune is correct for the application.
Witch will tune the best. Why more ppl got to MS price?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
A tune is a tune;
get it wrong and your engine will run bad irrespective of what system you are using or how much you spend !
Because in the past , the EZ only did fueling ,it didn't do spark control which is a major factor in tuning.
The EZ is self tuning. You set the base perimeters and the system builds the mapping as you drive. If you can make a post here, you can set up an EZ system.
I'm running the 302000 PN kit that goes perfectly with the TPI, MR, HSR and intakes of the like. Harness, ECM, hand held, and the other basic odds and ends reqd. When we set my system up nothing ran outside the bay, all connections were made in the bay.
Like I said I'll answer what ever you want to know about the EZ.
88SS6SPEED
11-11-2015 07:05 AM
MarineIROC
Southern California Area
09-16-2015 05:40 PM
