TPI plenum TB holes siamesed???
Been awhile since I messed with TPI. My last TPI I ported the plenum and siamesed the runner pair exits with good results. Later I saw someone siamese the throttle body holes and I wondered how that affected the tpi. Now it looks like I'll have another chance to mess with a TPI and I am debating on doing it.
Engine: 4++,350 & 305 CIs
Re: TPI plenum TB holes siamesed???
Only needed if over a certain HP level.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Your flow restriction is the TB bores so as long as the holes in the plenum are larger (whether one hole or two ) should make no difference
I suspect you would have to go to a mono -blade TB for it to actually be useful
Sanjay
08-12-2015 03:41 PM
