Return Line?
Car: A few things lol
Engine: 350 tpi supercharged and a 383 stro
Transmission: Both 700r4s
Axle/Gears: 3.23s and 3.54s
Return Line?
which line is the return line on a 350 TPI car anyone have pictures im getting ready to hook up an FMU I just want to make sure I have the right line....
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Return Line?
Car: 82 Z28
Transmission: T400
Re: Return Line?
Ok I think I got the right line its the smaller of the [2] I hooked up the FMU to the smaller of the two i think that's right problem is the FMU isn't raising the pressure up to much maybe like 50ish psi I would think it should raise it a lot more then that unless the rate isn't that high...im wondering if I shoukd buy a fixed rate 8.1 and take the procharger one off....
Car: 82 Z28
Transmission: T400
Re: Return Line?
From everything ive been reading 6 psi 22lb injectors I should be using a 8.1 ratio FMU this is a procharger FMU I think adjustable from 1.1 to 12.1 well I don't think its working because I only saw a little increase in fuel pressure under boost...Im wondering if the FMU is no good maybe the disc is dry rotted can I use a vortech rebuild kit and get a set rate of 8.1 or should I just buy a new one that is set for 8.1 ??? im lost here car is still lean under boost weird thing I had the adjustable regulator set to like 55 psi under boost it went to 13 still lean but with the regulaor set at 40 and the FMU is only went to like 50 and 15 on the air fuel gauge weird telling me its not enough fuel pressure...telling me the FMU cant be working right....
