'90 Iroc Died while I was Driving, help please!?
Old 10-15-2013 | 08:09 PM
KingsHustleLA's Avatar
Car: 1986 Camaro
Axle/Gears: 411
I was driving home from work then the car stalled out on me, it started back up & I got home, then I started it an hour later and when I would hit the gas the car would start shaking, I made it about 150 feet down the street before it died & the starter would crank but the car would no longer start up. The check engine diagnostics gave me no codes besides the "12" then to start trouble shooting I swapped the ICM and nothing happened, the fuel pump primes when I turn the & the fuel filter is a year old, can I get any suggestions?
Old 10-15-2013 | 09:31 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: '90 Iroc Died while I was Driving, help please!?
Pull some spark plugs
Wet plug ; no spark
Dry plug ; no fuel
At least that gives a direction to troubleshoot in
Old 10-15-2013 | 11:44 PM
mcquigg's Avatar
Car: 85 T/A
Axle/Gears: BW Limited Slip 3.27 w/disc brakes
After you hear the pump prime check the schrader valve on the fuel rail to see if your getting enough fuel, you should see a good sized geyser, have a rag handy. I had almost the same symptoms when my fuel pump failed.
Old 10-16-2013 | 05:00 AM
ChrisV's Avatar
Car: 1990 Iroc
Engine: 305 tpi
Wet plug ; no spark
Dry plug ; no fuel
I agree, Ive had my injectors and my ignition coil fail on me and both gave very similar symptoms as the OP explained. Test for spark/fuel and go from there!
Old 10-16-2013 | 07:19 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Can only check that with a gauge , notwithstanding having the correct pressure at the rail does not equate to having fuel in the cylinders
Old 10-16-2013 | 08:38 AM
87camaroirockid's Avatar
Car: 1987 iroc
Transmission: 700r4 with shift kit
Axle/Gears: 3.08
probably your fuel pump if it was a 4th gen i would tell you it was the optispark but i dont think tpi third gens had that
jklein337
09-19-2018 07:23 PM
Andrew6.688
12-13-2015 11:59 AM
Wade787b
09-29-2015 02:15 PM
mustangman65_79
08-11-2015 04:17 PM
